There were several hundred similar cars, all Sapphires rather than hatches, found from the same run, all bar a few were spirited away by Ford to have the section properly drilled out and replaced at [Ford's] expense, rather than letting the car get a bad reputation. Watchdog, part of the "That's Life" show on the BBC back then, did run a piece on this issue but nobody could have taken any notice as Ford went on to sell several more Sapphires.
Well done for saving this, it seems just five minutes ago that the roads were wick with the bloody things and now they've suddenly become harder to find than Cortinas. The Sierra was a decent car but that didn't matter to rust, which ate most of them. That DOHC engine was a good one, although the advantage of timing chains over belts was negated in its case because Ford's monkey metal chains tended to break at far shorter intervals than belts would have required attention. Now though, with a modern chain and a set of the upgraded guides & tensioner, they're quite possibly one of Ford's finest heroic failures.
