vulgalour
#261 Post by vulgalour »
Finally, a break in the weather! That meant I could get on with sorting out the doors. All the doors open and shut properly, the two awkward ones could probably do with some fine adjustment as you do have to slam them a bit to make them shut properly, but they go in the holes and stay there.
Panel gaps on this side are much better too, almost even all the way top to bottom. It's as good as I can get it on my own and it's good enough.
Other side sorted too, much better fit achieved here.
Fitted the two catches on the driver's side and the door handles I previously couldn't fathom just dropped on no issue this time around, weirdly. Refitted the various rods and clips as needed and actually have quite a few spare plastic plugs and clips now which I'm sure will come in handy in the future. Locks work, handles work, it's all good.
Rear door quarter lights refitted which were surprisingly easy, though I did learn it's easier to fit the door top trim before fitting the quarter lights. Quarter light bars had fresh rivets put in, first time I've done that and very easy it was too, I highly recommend the Wilkinson's hand rivet gun for this job and it was £8 well spent I think.
After a spot of lunch I went out again with the intention of fitting more of the doors up but the weather had changed and it was bitterly cold and threatening to rain so instead I took the opportunity of neighbour's son being available to help bolt the bonnet on and removed the carburettor so I can rebuild and clean that inside later tonight/this week. Bonnet needs a bit of fine adjustment to be perfect but it's perfectly functional as is.
I'd run out of bin bags and tape so I used cling film to wrap the window holes up as a temporary measure until I can get someone to help refit the door glass.
I wanted to get a few interior jobs done but there isn't enough light to work in with the doors on the car shut so that's going to have to wait a bit. I still feel as though I'm on target for an end of February MoT attempt.
#262 Post by Luxobarge »
vulgalour wrote: It's as good as I can get it on my own and it's good enough.
vulgalour wrote: Bonnet needs a bit of fine adjustment to be perfect but it's perfectly functional as is.
Well that was the attitude of the blokes that made them in the factory when they were new, so yours should end up being perfectly authentic!
:D :D
vulgalour
#263 Post by vulgalour »
Panel gaps you can drive a bus down, then a Mini, then a quarry lorry, then a bicycle...
Just finished sorting out the carb ready to refit tomorrow. New base plate seal, float valve and float valve needle fitted, the float seems to move a bit more freely now. Hopefully this will resolve the chronic flooding issue.
#264 Post by TerryG »
vulgalour wrote:Panel gaps you can drive a bus down, then a Mini, then a quarry lorry, then a bicycle...
Do you work for Land Rover?
#265 Post by Mitsuru »
I was thinking \Chrysler/dodge or is that Fix It Again Tomorrow(polite version of FIAT joke) :lol:
vulgalour
#266 Post by vulgalour »
Tiny update from the caretaker of the Renault in that the engine appears to be seized. No great surprise. There's a little bit of movement when attempting to rock in gear or turn over by hand but not enough to risk firing it up. I've suggested getting the head off and putting some oil in the bores and letting it steep for a bit to try and free things off, previous owner of my red Princess did this to good effect. Really, it's about time this car threw up a real problem, it's all been a bit too straightforward so far.
#267 Post by Mitsuru »
Why not just remover the spark plugs and spray penetrating oil directly in the cylinders.
I did it on the V6 over a couple of days, but you might consider spraying it once a day
for a week and there might be no need for removing the head!
#268 Post by TerryG »
I have done it with warm diesel down the bores of an rv8 before, it worked a treat.
#269 Post by kevin »
i would agree, plugs out and small, daily doses of diesel.
once (hopefully) it frees up, change the oil before attempting to fire it up.
good luck
#270 Post by tractorman »
An alternative is cola - even the cheaper versions will do, it's the phosphoric acid in it that does the job.
In this case, the old adverts were right: things go better with Coke!
