Early Javelin Restoration
Re: Early Javelin Restoration
#211 Post by Grumpy Northener »
Centre outrigger / jacking point tacked to chassis but left unattached to sill to enable minor adjustments to be made whilst gapping the door apertures
#212 Post by Grumpy Northener »
B post jig left in place until sill is fully welded to outrigger hence ensuring correct alignment of doors
Fitting of jack checked to ensure that it did not foul the sill
#213 Post by Grumpy Northener »
Door apertures methodically reworked until satisfactory gapping was achieved
Some metal being reduced 0.5mm at a time - other areas of the panels apertures built up with weld and cleaned up
whilst further sections required work with the hammer / dolly / 4 x 2 timber with a lump hammer - eventually getting to a point where I was happy with the gapping - next job is to temporary attach the front / rear wings to ensure the gapping between the doors is acceptable.
#214 Post by Grumpy Northener »
Still making progress albeit slowly - so wings on I could align the lower gaps / apertures - but they were all over the place
rear wing aperture with chisel utilised as spacing tool
Front wing to door aperture - 4mm gapping at the top - 4mm gapping at the bottom and 10mm between - how does that work then ?? :?
#215 Post by Grumpy Northener »
New wing mounting brackets made up
Ready for welding on
#216 Post by Grumpy Northener »
Working methodically I started to gain results with the gaps - still more fettling required though and what's not visible at this stage is that about 100mm of the wing edge up to the door is rotten and will need to be replaced with fresh metal
#217 Post by Grumpy Northener »
Front wing edge was also rotten and had various bodges from previous repairs
Wing support edge was dead too
New support edge fabricated and let in
Repair section made up and ready for welding in once a couple of minor adjustments have been made
#218 Post by Grumpy Northener »
Jack has been gathering all the chrome together so it can be replated - but a few repairs were needed first
The hubcaps all needed minor dents taking out of them - just gently tapped out from the rear - then sanded back with some P80's and kept working with the hammer dressing out any low areas whilst dressing down any high spots
#219 Post by Grumpy Northener »
The original grille had received a bash at some stage - it looked clean enough but was far from straight
We had removed another from a car that was scrapped
Although quite straight the chrome was poor
#220 Post by Grumpy Northener »
So we set about stripping it - the grille slats are made from very thin pressed brass strip and are riveted to several metal vertical brackets on the rear
This called for much careful drilling and dismantling
