Early Javelin Restoration
Ian
Re: Early Javelin Restoration
#161 Post by Ian »
That is awesome work. I have always loved Jowetts tho sadly you really don't see that many any more which makes your restoration even more unusual. Top work :D
#162 Post by UKJeeper »
Nice write up/blog. Lot of love going into that car.
(though i was expecting the thread to be about an AMC Javelin! :D )
#163 Post by JPB »
UKJeeper wrote:.......AMC Javelin! :D
A what now? :? ;)
#164 Post by Grumpy Northener »
Thanks for comments guys - much appreciated - onward progress as of yesterday
Lower section of the D post made up and welded in
Closing panel at the bottom of the inner wing / wheel arch in the making / trial fitted
Last edited by Grumpy Northener on Mon May 06, 2013 12:00 pm, edited 1 time in total.
#165 Post by Grumpy Northener »
Welded in - mig on the seams and spot welded on the flange edges & where the two skins are flush
Just a closing panel to make up between the bottom of the wheel arch & the D post -once this is complete the out rigger can be attached
#166 Post by Grumpy Northener »
Closing panel made up and tacked
Outrigger in final trial fitting
#167 Post by Grumpy Northener »
Outrigger now in place - flanges to edge of D post and sill were spot welded to match factory methods of assembly - closing section for end of outrigger made up and final welding of area completed
Cleaned up
#168 Post by Grumpy Northener »
A small area of the inner wing had rotted out adjacent to the rear suspension mounting - water ingress had found its way down from the quarter glass in the rear wing and been held in this area forming a well - in turn the metal corroded from the inside out
Repair completed with new metal let in
#169 Post by Grumpy Northener »
Next was the O/S 'D' post
Which was quite weak in some areas
#170 Post by Grumpy Northener »
Effected metal cut out , new sections fabricated and let in
Cleaned up
Completed
We are just contemplating making up a trolley to mount the shell so that we can remove from the workshop and get it on to a trailer - we would like to exhibit it at our national rally in a couple of weeks time (25th & 26th May) see listing in events / meets / local clubs section - just gives everyone an insight into how much work is involved in a full restoration.
