Early Javelin Restoration
Re: Early Javelin Restoration
#151 Post by Grumpy Northener »
Lots of small rust perforated areas to sort around the rear now
Inner section of the rear panel which had rotted out on a seam edge
Another one completed
#152 Post by Grumpy Northener »
Rear window aperture - outer edge / roof skin
Sectioned
Shot blasted
Completed - Most of the bodyshell repairs shall be lead loaded to make good any deviations to the metal
#153 Post by Grumpy Northener »
Next was to repair the area to the lower centre of the inner rear wing
Previously smeared in body filler by previous owners / bodgers
Close inspection reveals yet another rust weak structure
#154 Post by Grumpy Northener »
Fortunately the underside of this right angled section was very solid so I opted just to remove the rust holed side and replace it with some 1.5mm plate
Welded in
Cleaned up and ready for the outer skin to be fabricated & welded in - a section that is on-going and shall be completed on my next workshop visit.
Last edited by Grumpy Northener on Sun Apr 07, 2013 8:41 pm, edited 1 time in total.
#155 Post by Grumpy Northener »
The offside rear panel joint to the rear shroud / outer wing support panel was also in the same state as the nearside
View from the underside with the failed seam of very thin metal - this is in direct line of the rear wheel so it catches all the road crud
So this was dealt with using the same detail as the nearside
This is also on-going and will be completed on my next visit to the workshop
#156 Post by Grumpy Northener »
The car had very poor panel gaps when it first arrived at the workshop - then again Javelin panel fits were quite poor when the cars were new - but the boot lid was a dreadful fit - taking paint off in some areas and in others you could drive a bus through the gaps - The poorest fitting panel on any Javelin tends to be the boot anyway - with its wrap around profile and swept compound curvature there is no surprise. Further to this is the fact that the inner frame of the panel is aluminium and the outer skin being steel so splayed / out of shape panels are not unusual. The original boot had been forced closed on top of something in the boot which in turn had crushed and cracked part of the inner frame so I had sourced a reasonable spare from the Jowett Club spares stock - I just had to repair the split on the inner frame by the hinge
So out came the TIG welder and once I had the repair welded and cleaned back I could try for a fit
Last edited by Grumpy Northener on Sun Apr 07, 2013 9:21 pm, edited 1 time in total.
#157 Post by Grumpy Northener »
Starting with the one panel that would be difficult to alter (closing edge of the roof skin) I set the gapping by adjustment on the boot hinges - once I was happy with this I used it as a reference point and worked towards the rear of the car - some areas had to be dressed up / down with a hammer & dolly
Other areas had be dressed in / out again with the hammer / dolly - A couple of areas had to be slightly reduced with the angle grinder - mainly the bottom offside edge of the boot - again I was not surprised as the car had sustained pretty heavy impact damage at this point at sometime in the cars life - this in turn opened the edge up on the outer skin return - so by grinding / reducing back by a few more mm in order to allow a build up of weld before cleaning back with a flap disc on the angle grinder
Last edited by Grumpy Northener on Sun Apr 07, 2013 9:25 pm, edited 2 times in total.
#158 Post by Grumpy Northener »
I kept working the boot lid & the aperture until I obtained as close a fit as I could, There are a couple of areas that I will have to lead load to achieve the correct gapping & profile fitting - especially around the bottom corners of the panel adjacent to the lower shroud / rear panel - but these were lead loaded at the factory as original anyway
This is a significant milestone in the cars restoration - apologies if I sound smug but get the boot lid to fit correctly on one of these cars is a nightmare - I know of Javelin owners who have battled for years to obtain a correct fit on this one panel alone - now you can also see the style & shape of the car coming together - it always helps but we still have a long way to go yet :shock:
#159 Post by Grumpy Northener »
Its still happening - just very busy with lots of other things at present - but have still made some progress
Outer skin to the off side inner wing was completed
Next is the rear suspension mountings / D post / sill / rear out rigger with the main problems hidden behind this mess
With the usual patch over rust theme that has been found in the rest of the car
#160 Post by Grumpy Northener »
Trial fit of the repair template
Fabricated repair to inner skin completed and the area shot blasted as the area is all hidden once the outer skin gets completed
With the outrigger cut out and the bottom of the D post cut away I could start to trial the new out rigger and use as a reference point for the fabrication of the D post lower sections
