ford galaxy
Re: ford galaxy
#151 Post by JPB »
:idea: Rich, is this noise happening when you're alone in the car or only when you have passengers?
Re: ford galaxy
#152 Post by rich. »
only when parking, & on full lock.. ive checked the level & its ok...
Re: ford galaxy
#153 Post by TerryG »
Ot only makes the noise on full lock or it makes it the whole time you are parking or just when you are turning the wheel while parking?
Re: ford galaxy
#154 Post by rich. »
not all the time, full lock & start up & parking speed... worst is full lock but it never did that before :?
Re: ford galaxy
#155 Post by rich. »
had the belly panel off & had a lookie, everything seems ok except its squealing a lot more.. could it be the belt or the idler pulley??
Re: ford galaxy
#156 Post by TerryG »
does the belt look warn? I suspect you will have to take the belt off to check the idler pulley bearings unless there is better access than I remember to get a screwdriver / probe to it when the engine is running to listen to them.
Re: ford galaxy
#157 Post by rich. »
belt was only changed 2 years ago /60000 km & looks in good condition....
Re: ford galaxy
#158 Post by TerryG »
I do all of mine annually when I give the cars a go over pre-MOT but 3700 miles doesn't seem like a lot for a belt. I have had problems previously with belt squeal after a coolant leak. I'm not sure what it did to the surface of the rubber, it looked fine but sounded dreadful.
If you have a long screwdriver try listening to each set of bearings you can get at but as you say the noise is worse on full lock, it is almost certainly the pump / rack, possibly contaminated fluid. when was the last time you changed it? does it smell burnt?
Re: ford galaxy
#159 Post by rich. »
the water pump was leaking last year & was changed...new cam belt etc, the guy seemed to think the belts etc were ok..
Re: ford galaxy
#160 Post by rich. »
had the mobile mechanic check it today, the idler pulley is knackered....
