Early Javelin Restoration
Re: Early Javelin Restoration
#141 Post by Grumpy Northener »
Repair complete & bumper iron re-attached
#142 Post by Grumpy Northener »
Peter spent most of Sunday going over the bodyshell with the angle grinder fitted with a polycarbon disc to remove the last traces of paint after stripping
Whilst also highlighting many problems
Heavy pot marking to the roof skin
Rust has eaten through in some odd places - this is just under the rear window apperature
Last edited by Grumpy Northener on Mon Apr 01, 2013 9:41 pm, edited 1 time in total.
#143 Post by Grumpy Northener »
It has become obvious that the car has been the subject of a previous restoration along with some very poor bodged repairs - there is extensive lead loading over previous repairs and all of the doors have suffered from impact / accident damage at some stage
The offside front door holds several areas of heavy lead loading over dents & rust repair sections
Nearside front door has many previous repairs and rust damage - it will now require the bottom 100 mm of the door skin to be cut out and replaced
#144 Post by Grumpy Northener »
Meanwhile back to the structural repairs - the upstand for the boot floor / tool tray had seen patches of braised on metal and was quite thin on the leading edges
I cut & folded a new section but then had to replicate the swaging on the panel - so I made a small jig up and with the help of a broom handle and suitable hammer
obtained something close to the original swaging
#145 Post by Grumpy Northener »
Ready for tacking up / trial fitting
With panel trial fitted the tool tray hinged lid was checked for fit
#146 Post by Grumpy Northener »
New end tabs were fabricated and welded to the upstand panel prior to final fitting - once the panel repair had been seam welded and cleaned back the panel was fully welded in place - I used spot welds where possible to replicate the factory finish (although none of it is seen when the boot floor is fitted) Upstand panel refitted / cleaned back - new captive nuts were spotwelded in place as required - the captive nuts retain the boot floor which is a plywood panel
Tool tray lid fitted without issue to upstand panel and opens / closes nicely
#147 Post by Grumpy Northener »
Just a few more areas on the rear of the car now before I can start to cover the structural repairs down the offside of the shell
This is where the rear panel meets the rear shroud / wing support and it looks ok
Buts its not under the lead is a bodged seam that is rotting from the inside out
With the lead burnt off a reveal of the previous restoration where the factory seam has been gas welded together - the metal is weak and pinholes are showing through
#148 Post by Grumpy Northener »
Seam cut out
New section fabricated in two sections - shrunk to obtain radius and spot welded together off the car (spot welder cannot reach with the repair sections on the car)
Ready for welding in
Willy Eckerslyke
#149 Post by Willy Eckerslyke »
Superb work, an inspiration to us all!
#150 Post by Grumpy Northener »
I need the inspiration myself some days with this one - the car initially came to me for a bare metal paint job whilst the rest of the team fitted a rebuilt engine & box and sorted a few of the mechanicals out - none of us (including Peter the owner) anticipated finding the amount of weakness / rust / bodge in the bodyshell - anyway - onwards:
Nearside of rear panel completed - I will lead load the area as per the original factory detail
Underside of the completed repair
