Rebuilt the cooling system and apart from the bottom hose needing a notch to make it fit snug, it all went together really well. It made a huge difference using new jubilee clips and once they weather in a bit im sure it will look less shiney
Refitted the dynamo, together with a new fan belt, Will adjust that up tomorrow after work then fill the cooling system.
As long as we are leak free, I can then turn her round ready to start the paint work..this may involve driving around the private road quite a bit until I find the correct direction to slot her in the garage
need to make sure I get her positioned correctly in the garage as I will be placing her on concrete trench blocks (under the axles, but will use some timber offcuts between the axle and concrete block) in order that I can remove the wheels ready for powder coating in January 2014.
