Early Javelin Restoration
Re: Early Javelin Restoration
#121 Post by Grumpy Northener »
The leading edge of the inner wing where the outer wing fastens was perferated for much of it's length - the wing beading being mainly to blame as this was a fabric type which had retained moisture - hence the rot
WP_20130224_011 (1).jpg (41.87 KiB) Viewed 1958 times
Note the marking of the captive nut centres that retain the outer wing bolts
From the inside
#122 Post by Grumpy Northener »
The areas were cut out in sections to help avoid any distortion whilst replacing the sections
I made up the repair sections and carefully marked / drilled the holes for the outer wing mounting - a captive nut was then spot welded to the repair section prior to it being welded in situ
#123 Post by Grumpy Northener »
Inner wing leading edge repairs all but complete
This just left a couple more sections - the easy one first
#124 Post by Grumpy Northener »
Just the rear bumper mounting then - which looked ok
Until
And behind the sectioned panel lies this mess
#125 Post by Grumpy Northener »
Poor repairs to bumper mountings had been undertaken previously but are hidden in the corners of the tool tray within the boot of the car
Which makes it very hard to access the said areas
The support / upstand panel for the tool tray was also suffering with rust and poor previous repairs on the leading edge of the tool tray floor
#126 Post by Grumpy Northener »
It will be easier to repair the upstand panel with it off the car so the spot welds were drilled out and the panel removed
The side closing panel to the tool tray was also removed once the welds had been unpicked
The rotten sections could now be removed
#127 Post by Grumpy Northener »
A small section of the supporting rail was very thin / in holes so this had fresh metal let in
Result of the removed sections
#128 Post by Grumpy Northener »
Meanwhile Keith has been busy shot blasting / checking suspension / axle parts and getting them into first stage primer
#129 Post by Grumpy Northener »
Very busy with the day job at this time of year so little time to post but progress continues to be made
Tool tray floor let in and bumper iron reinforcing section fabricated
Welded in
Last edited by Grumpy Northener on Sun Mar 31, 2013 10:07 am, edited 1 time in total.
#130 Post by Grumpy Northener »
Closed in section treated with zinc primer
Outer section completed and bumper iron re-drilled / attached
Inner section cleaned up and the tool tray side support reattached
