Early Javelin Restoration
Re: Early Javelin Restoration
#111 Post by Grumpy Northener »
Before packing up for the day I made this closing section up for the end of the chassis box to the factory pattern
Welded in
Once this is cleaned up (next workshop visit) the whole area is then overskined with a plate that comes down to weld in around the lower rear suspension link.
#112 Post by Grumpy Northener »
Drummond - one of our fellow Jowett car club members was down from Scotland for an overnight stay - Drum has been around Jowetts heading on for 50 years or so and there are not too many tricks he is not aware of - so with this in mind we put him to good use
2013-02-05 11_47_44 _480x640_[1].jpg (4.96 KiB) Viewed 1788 times
Drum has a keen knack for rebuilding the quite complex coloumn gear change shafts
2013-02-05 12_01_10 _480x640_[1].jpg (3.96 KiB) Viewed 1788 times
The shaft was taken apart - refurbished as required - the old one had quite a lot of play in it which makes for a lot of fun when it attempts to select two gears at once
#113 Post by Grumpy Northener »
Once rebuilt and set up to take the play out, Keith then soda blasted the externals of the shaft
2013-02-11 16_26_59 _640x480_[1].jpg (2.76 KiB) Viewed 1788 times
Cleaned up it was then sprayed with a zinc primer
So thats one bit of the mechanicals completed and ready for paint - there is a quite a lot of painted metalware within the interior - dashboard / window trims / steering column etc and these will all be repainted along with the column change shaft at later date in the restoration
#114 Post by Grumpy Northener »
It's a very busy time of year for thr day job - but I am making some progress - the closing panel was made up for the bottom front of the rear inner wing and the inner face sprayed with a zinc rich weld through primer
Welded in
Cleaned back - where the two skins meet towards the outer edge I managed to get some good spotwelds in on the panel
#115 Post by Grumpy Northener »
Next was to sort the lower N/S D post out - this abuts with the rear outrigger
rear side made up and let in
#116 Post by Grumpy Northener »
Front section of D post looks ok - but hides yet another bucket of rusted out / overplated metal
Using the rear section for reference the front can now be cut out
The sill section that abuts the bottom of the D post was also a mess of overplated rust
#117 Post by Grumpy Northener »
The end of the sill was sectioned and new metal fabricated / let in
Closing sections could now be let in to replicate the factory original seams
#118 Post by Grumpy Northener »
The outrigger could now be attached
Closing panel fabricated and let in to the outrigger
Another area ticked off the endless list of welding & fabrication
#119 Post by Grumpy Northener »
Upper sections of the D post had also suffered from the tin worm / previous repairs
#120 Post by Grumpy Northener »
Repair areas cut out & welded in
