iveco
Re: iveco
#101 Post by TerryG »
As Tractorman says, if the holes are large enough then blanking grommets (with some sealant) are the way to go. If they are screw hole sized then you could get away with some epoxy from the inside then sanding the bumps back from the top.
It is always amazing the bodges you see with vans. People just don't seem to care as much as they do with a car.
Re: iveco
#102 Post by rich. »
id get some grommets if i could!!
ill just use a bit of tape to block them off for now & ill put the headlining back in when its dried out..
Re: iveco
#103 Post by TerryG »
The builders bodge: If there is a hole, bung some tape over it and hope the customer doesn't notice until they have been paid ;)
Re: iveco
#104 Post by mach1rob »
Gaffer tape FTW!
Re: iveco
#105 Post by tractorman »
Well, if you ain't got grommets, do what our local tradesmen do - plenty of silicon!
I would have said builders, but I don't know what they use - they never turn up. OK, I'm bitter and twisted, but I am cold and the builder that came in June to see about fitting a fire hasn't turned up yet. My phone bill only has one chargeable number on it - the builder's mobile!!
Re: iveco
#106 Post by TerryG »
I'm sure Rich would come and fit a stove with gaffa tape for you if you paid for the flights, hotel, meals and tape ;)
Re: iveco
#107 Post by rich. »
can give you a quote, but gaffa tape doesnt treally work with stoves.. i tend to do as the client asks as long as its not too daft :lol:
Re: iveco
#108 Post by rich. »
have used nuts & bolts, bolts sticking through the roof & ground them off..... bit of primer & plumbers mait..
Re: iveco
#109 Post by TerryG »
wouldn't it have looked better with the bolt heads on the outside? you could have got those fencing bolts with the flat round heads.
At least you shouldn't get a free shower whenever you drive in the rain now. Between that and a new starter you will think you have a new van! ;)
Re: iveco
#110 Post by rich. »
not forgetting the new tyres!!
i tried to get gutter bolts but couldnt find any so i made do with what i had... system d as my old mate would say :lol:
