MGB Brake fluid
jagiron
Re: MGB Brake fluid
#11 Post by jagiron »
Thanks guys lots to think about there,do`nt worry I know all about the "age" thing.
Thanks again.
History
Re: MGB Brake fluid
#12 Post by History »
No no no.
Dot 3 4 and 5.1 are glycol based they are not mineral. They do not mix with mineral oils. Mineral oil will damage tve seals in a MGB.
Dot 5 is silicon.
MGB use Dot 4 of any make you want including supermarket stuff. Change every 2 years.
This brakes 101 before working on brakes one must understand the various brake fluids because getting it wrong WILL cause brake failure and at best a total brake rebuild of all rubber bits. Or take up the harp and don angel wings.
Bob
Flatlander
Re: MGB Brake fluid
#13 Post by Flatlander »
History wrote:No no no.
Bob
The key word in Dot 3, 4, 5.0 brake fluids is ethylene, as in poly-ethylene-glycol. (PEG) Ethylene is a product of the petrochemical industry, ie oil, therefore, a mineral liquid.
Re: MGB Brake fluid
#14 Post by JPB »
Flatlander wrote:.....The key word in Dot 3, 4, 5.0 brake fluids is ethylene, as in poly-ethylene-glycol. (PEG) Ethylene is a product of the petrochemical industry, ie oil, therefore, a mineral liquid.
^^^ Yes, that. :thumbs:
History wrote:No no no..
Can we have a defibrillator on standby here please.. ;)
History
Re: MGB Brake fluid
#15 Post by History »
Dot 3 4 and 5.1 are not mineral oils.
Bob
Re: MGB Brake fluid
#16 Post by JPB »
History wrote:Dot 3 4 and 5.1 are not mineral oils.
Bob
Yes, they are. Exactly as Flatliner explained. Nobody said they're from the same level as fuel oils and such, but they are nonetheless from the same crude source and correctly referred to as mineral.
Please read up on organic chemistry.
Flatlander
Re: MGB Brake fluid
#17 Post by Flatlander »
Flatlander has now Flatlined, but the defibrillator was on standby, so no problem! :lol:
Re: MGB Brake fluid
#18 Post by rich. »
Bob
just for you bob
https://www.youtube.com/watch?v=qM5W7Xn7FiA
jagiron
Re: MGB Brake fluid
#19 Post by jagiron »
Sorry guys getting a lot of conflicting info here, I am taking it that Dot 4 is OK for MGB,bring the de.fib. mother !!!
Ta again............... :? Ron
Re: MGB Brake fluid
#20 Post by gazza82 »
DOT 4 will be fine.
I was going to throw Super DOT4 into the mix ... But thought it might be too stressful for some ... :-)
