Volvo S40
Re: Volvo S40
have you tried belgian beer? aparently its better than their cars
Richard Moss
Re: Volvo S40
V/S40 are Dutch built, are they not? Up to 2004, anyway
The engine bolts sound like the one on the Honda engines Rover fitted. The only way I could shift the crank pulley bolt on an 827 was to wedge the breaker bar against the ground and turn the engine over on the starter motor
Re: Volvo S40
Re: Volvo S40
That is because some people tighten the crank pulley bolt by wedging a spanner between the crank and the block then putting a 6ft bar on the bolt and jumping on it. I really hope I don't have to change my oil pump any time soon............Richard Moss wrote:The only way I could shift the crank pulley bolt on an 827 was to wedge the breaker bar against the ground and turn the engine over on the starter motor
Richard Moss
Re: Volvo S40
In the case of the Honda-engined Rovers, that's how they came from the factory (C27 V6 and D16 I4 alike). It's not just the crank pulleys, either, it's all the engine related bolts - plus they were odd sizes like 12mm and 14mmTerryG wrote:That is because some people tighten the crank pulley bolt by wedging a spanner between the crank and the block then putting a 6ft bar on the bolt and jumping on it. I really hope I don't have to change my oil pump any time soon............
Re: Volvo S40
found a tidy lhd one on autotrader...can you reccomend them?
- SirTainleyBarking
Re: Volvo S40
Thats how I suspect Ovlov dealers do the job. Hit it with a rattle gun. I've got one of the leccy ones that hooks onto the battery. Not sure if it would be man enough to do the job in place of a proper air powered oneUKJeeper wrote:I know i'm teaching you to suck eggs, but when i found myself snapping breaker bars on my YJ front wheel hub nuts, i eventually had a mate bring his Air impact wrench over and run it until the hub nut surrendered.
Richard Moss
Re: Volvo S40
I broke my electric one doing the crank pulley on an 827. I also broke my (old) breaker bar but the new Halfords* one I bought as a replacement was man enough for the job.
* actually it may have been machine mart ......
Re: Volvo S40
Perhaps a case for 3/4" drive sockets?
About forty years ago at the David Brown agency where I worked, a fitter was using a 1/2" Snap-On breaker bar with a 1 1/16" AF socket to remove a back wheel nut on a tractor when the end broke off. Snap-On had a replacement there the next morning and didn't seem concerned that the fitter used a six-foot scaffold pipe and two apprentices to try to get the nut off! 3/4 drive socket stuff was stupidly expensive in those days - even I have four or five 3/4" sockets and breaker bar now - eBay has changed things somewhat!
I broke my Halfords 1/2" breaker bar (a 18" or so one) trying to remove a similarly large wheel nut from my trailer and they gave me a new one - they didn't mind about the abuse as it was guaranteed for life. I bought the 3/4" drive stuff after that: it's OK having a warranty, but when the item breaks and the machine is blocking the drive - or needed straight away, it is a PITA!
Richard Moss
Re: Volvo S40
I now have a 3/4" drive socket set. It makes short work of Jeep hub nuts!
