Definately DO NOT use bricks or blocks
I've had to deal with fixing cars on a driveway with a 15 degree slope for years. Removed engines, gearboxes, changed clutches etc...
I used a 2-ton engine crane to lift the front of a car up by the engine crossmember and stuck ramps under the chassis with timber blocks on top and then chocked the rear wheels for good measure. I have also used lengths of timber bolted underneath ramps to raise them up by 9" and made long timber ramps to get the car up on to them without any problem.
Fence posts have proved perfect for the job - new ones, not old rotten ones please.
Also useful to tie the higher end of the car to something heavy...like another car...while you are doing the lift. Tow rope, ratchet strap or steel cable...
If you've ever seen the tank restoration shows on the Discovery channel they use railway sleepers to support tanks weighing several tons when the guys are working underneath them, so timber should be perfectly OK for a car.
