Getting to destroy the wrapping paper is pretty much his favourite thing in the world.
The main box waiting under the tree for me this year - completely unexpectedly - contained this.
This contains a 3D printer.
Immediate reaction "Oh god...this means I need to learn how to drive Blender!" Which is a bit of software I've generally run in terror from on all previous encounters!
Would have been nice to get to set up the 3D printer this evening wouldn't it?
Life had other ideas though. Before we'd even tidied up from dinner it became immediately apparent something was amiss with the fridge. It was 15C and the lower veg drawer was stuck in place by a block of frost at the back.
Fine...everything out and start pulling it to bits.
Became immediately apparent we had a defrost issue - not least because the lower moulding there (which is the airflow duct covering the evaporator) was completely frozen in place.
As it was clearly stuck to the evaporator I couldn't be too rough with it - but eventually I got it free.
That fan hasn't been doing anything for a while...
Yes...definitely looks like the defrost heater has died. The inch and a half deep block of ice immediately below the heating element tends to suggest it's not been doing much. For those not familiar with the innards of refrigeration equipment, he heater is the black thing below the silver coils.
Also...the bits of a fridge you can't get to to clean become utterly disgusting.
After some attention with a hairdryer I got the fan freed from the ice cube it had turned into and it seems to have survived. I chiselled the block out of the condensate drain tray, blasted the drain clear (no idea if it was clogged before it froze up or not), and reassembled everything.
Sadly this fridge is intelligent enough to know if anything is unplugged so will just throw error codes if you try to power it up in bits...so I had to put it all back together before I could test things.
I also had to dismantle the door hinge to find and defeat the switch so I could ascertain whether the fan was working...as it only runs when the door is closed.
Fan is running, cool air is being circulated...good. Everything can go back in.
I'll need to investigate why the defrost heater isn't working but that can wait until tomorrow. I can easily test whether voltage is being supplied to the circuit from the main control PCB.
I've done work on this board before as the relay that controls the compressor burnt up a year or two ago. Was pretty painless really.
Credit where it's due to Samsung, by the standards of modern white goods this thing isn't bad from a service perspective. Everything is held together by normal Philips head screws (all of which are identical) with no daft clips, and even the pin headers in the control unit are labelled. It's also 18 years old so isn't doing bad to be honest! Especially given the abuse the kit in this house took before we moved in...The dishwasher for one was scrap! I do question why such control circuitry is needed for a fridge freezer though.
Given the freezer seems to be working normally my money is on a dead heater element, in which case it should be a pretty simple fix. Which is appreciated as American style side by side fridge freezers are extremely expensive!
Seriously though...Christmas day?!?
