Bit more progress today before it got really bitingly cold, from here on it gets fairly easy. First up got the boot bolted down and put the spare radiator I liberated from the banger car in the boot. Everything seems to line up first try, panel gaps are good and the lock works. The keys and the user manual folder thingy I forgot all arrived in the post today, usefully.
Tightened up the bolts on the rear door this side and found that it needs adjusting quite a bit to get it to sit properly. The doors are attached with six nuts and the only adjustment is in the thickness of the shim and the slotted holes in one of the top shim plates. I'll figure it out, but for now the back door sits too low at the arch edge by a smidge. There's no latch or handle fitted yet but even without them in place I can see it's wrong. Front door, on the other hand, dropped on perfectly. I decided against swapping this door with the slightly worse one on the beige car because it's a lot of work to strip them down and get the lock barrels and glass swapped over, I'll just repair the door on the beige one instead because it's easier.
Got both doors fitted the other side too which still have handles and latches fitted. The rear door bolted up lovely and works perfectly fine with no adjustment required.
Front door has the same issue as the rear door on the other side and sits slightly too low preventing the latch from fully engaging.
I bagged the window holes to finish off today. Thankfully, the previous plastic doors I'd made had kept the weather out of the car completely so these should do the trick until I get the glass back in.
