WASHER FLUID HEATER
WASHER FLUID HEATER
#1 Post by Mitsuru »
As it is that time of the year as the temprature drops the screen wash freezes.
Anybody have any experience with heated washer fluid kits?
or has anybody made their own kit to heat their screen wash reservoir?
Re: WASHER FLUID HEATER
#2 Post by Mitsuru »
How I was thinking of doing it would be to put a heater into
the washer bottle operated by a micro switched relay.
There would be a temprature sensor for the micro chip to get
a reading and it would be switched on until the washer bottle
reaches the desired temperature.
The power to the micro chip operated circuit would first be
only operational when the ignition is in the on position and
also through a second switch on the dash to turn it off
entirely if not required during the spring and summer.
A plate inside and a plate outside with gasket seal to make it
water tight, with a Cooling Water Pre-Heater ment originally
as block heater for a VW or Audi TDI bolted through them.
There is a micro cip and sensor from maplins.
http://www.maplin.co.uk/temperature-act ... kit-220003
And the coolant heater plug
http://www.ebay.co.uk/itm/Volkswagen-Po ... 20b9da503c
What do you think?
spiny
#3 Post by spiny »
i've often wondered if just lengthening a convenient coolant hose in the engine bay and wrapping it round the washer reservoir would do the same thing ? it would take longer to warm up though.
1989 BMW E30 2.5 Tourer - Daily
1970 MG Midget - resto nearly finished
1978 VW Type2 twin slider - getting there, see link above ^
OneCarefulOwner
#4 Post by OneCarefulOwner »
Most aftermarket heaters I've seen work on the principle mentioned by Spiny; that way the ice is removed from the pipework first & foremost. Applying heat solely to the reservoir would not be of any assistance with clearing the frozen pipes under the bonnet & out into the jets.
Twitter | Blog | DropBox
#5 Post by Luxobarge »
I just mix some methylated spirit into the fluid, never froze when I did that last winter.
scimagain
#6 Post by scimagain »
Years ago I bought a screeenwash heater, length of metal pipe fitted into heater feed hose and surrounded by a plastic jacket containg the washer fluid, the unit connected in series between the washer pump and the jets. Simple idea and it worked very well for a number of years until the plastic lost its seal to the pipe.
The use of hot water for the screen good - all year round (it also worked well for bugs during the summer).
Add to the fluid a drop of meths as mentioned by Luxo and it was a very good system. One drawback was the intake of fumes through the heater inlet. Rather eye watering at times.
I'd likely buy another if I could find one.
Regards.
Mikey77
#7 Post by Mikey77 »
Have I missed something here? Why not just buy washer fluid that doesn't freeze? Cheap as chips in the shops over here (France).
#8 Post by Luxobarge »
scimagain wrote:Add to the fluid a drop of meths as mentioned by Luxo and it was a very good system. One drawback was the intake of fumes through the heater inlet. Rather eye watering at times.
Shorry - I jush don' see the prblm with that? hic! ;)
#9 Post by Luxobarge »
Mikey77 wrote:Have I missed something here? Why not just buy washer fluid that doesn't freeze? Cheap as chips in the shops over here (France).
I used a decent concentration of proprietary so-called anti-freeze washer fluid last winter, and it didn't work once it was below about -5 or so, sometimes less. Meths sorted it for good though, and it didn't need much.
jpsh120
#10 Post by jpsh120 »
On my Mk2 golf GTi the washer jets were heated via electrics. Its a few years ago that I had that car but I seem to remember the heated jets combined with undiluted screenwash made for a very good combination. Slighty off the original topic but may be worth considering?
1971 Sunbeam Rapier H120
