Minor van in progress
CustomMoggy
#1 Post by CustomMoggy »
1969 Moggy van project, will update as we go. from start to finish, a rusting wreck to a modern funcional vehicle, retro van with modern mechanicals, a bit like what VW did with the beetle but keeping the original shell.
DSC_0028 256.jpg (111.42 KiB) Viewed 6244 times
DSC_0009 256.jpg (104.4 KiB) Viewed 6243 times
DSC_0005 256.jpg (95.98 KiB) Viewed 6246 times
1951 Morris Minor split screen fwd diesel
1961 Morris Minor Ford 1.8 CVH rwd
1969 4 door Morris minor fwd diesel
1970 Morris Minor van fwd diesel
1983 Lola S2000 group C
2004 rover 75
2001 Fiat Ducato
1996 Transit recovery truck.
CustomMoggy
Re: Minor van in progress
#2 Post by CustomMoggy »
next pics, front suspension on the new chassis, ford escort van shortened rear axle, cab preparation
DSC_0009 256.jpg (139.87 KiB) Viewed 6238 times
DSC_0006 256.jpg (125 KiB) Viewed 6237 times
DSC_0030 256.jpg (112.75 KiB) Viewed 6239 times
2004 rover 75
2001 Fiat Ducato
CustomMoggy
#3 Post by CustomMoggy »
Being stripped back to the bare metal, front showing new chassis arrangement ready to take the front wheel drive unit. note the firewall has been changed to accommodate the engine, steering rack and servo. The lower arms are renault clio, as they are A frames there is no need for an anti roll bar. the piece of dexion you can see is temporary, it's there just to hold the wing trough in the correct position.
DSC_0002 256.jpg (101.45 KiB) Viewed 6188 times
DSC_0003 256.jpg (91.41 KiB) Viewed 6187 times
2004 rover 75
2001 Fiat Ducato
CustomMoggy
#4 Post by CustomMoggy »
Stripped Bonnet, front strut in place, custom built fuel tank.
DSC_0006 256.jpg (95.79 KiB) Viewed 6051 times
DSC_0005 256.jpg (91.07 KiB) Viewed 6054 times
DSC_0004 256.jpg (87.57 KiB) Viewed 6056 times
2004 rover 75
2001 Fiat Ducato
CustomMoggy
#5 Post by CustomMoggy »
Doors blasted and bottoms repaired, note steel not filler. The yellow paint on one door would suggest it's not the original, probably taken from a gpo van. Decided open air blasting is too messy so today we are going to build a cabinet, details will be posted on this thread.
DSC_0109 256.jpg (73.71 KiB) Viewed 6003 times
DSC_0108 256.jpg (92.86 KiB) Viewed 6005 times
2004 rover 75
2001 Fiat Ducato
CustomMoggy
#6 Post by CustomMoggy »
Fuel tank fitted, approx 20 gallons, with an approximate consumption of 60mpg the range should be about 1200 miles.
tank 256.jpg (101.9 KiB) Viewed 5998 times
2004 rover 75
2001 Fiat Ducato
22900013A
#7 Post by 22900013A »
60 mpg! I never knew they did that well!
paul
#8 Post by paul »
Wow
That looks amazing!
CustomMoggy
#9 Post by CustomMoggy »
It's getting a 1.5 diesel peugeot engine
2004 rover 75
2001 Fiat Ducato
CustomMoggy
#10 Post by CustomMoggy »
Built a blaster but decided it's better on it's own topic, so see blaster.
2004 rover 75
2001 Fiat Ducato
