I've recently picked up a 1971 Beetle with various 'bodges' one is in the fuel lines to the twin carb conversion. So I want to replace the whole lot from the fuel pump to the carbs.
The difficulty is the 2 carb inlets are 8mm OD and the fuel pump is a single 6mm OD outlet. To keep the joins to a minimum and avoid extra step up unions I really want a splitter like this:
But in metal and I'm finding it really, really hard to find.
Ideally one like this with a shoulder:
This one is actually the closest I found, but it's 8mm 5mm 8mm, and obviously I don't want the 5mm (1/4") inlet to be sloppy or too much of a restriction.
(http://www.carbuildersolutions.com/uk/p ... mm-and-5mm)
Any help gratefully received, thanks.
Help required finding a decent fuel union supplier
1986 VW Golf GTi, 1988 VW Golf GTi, 1993 BMW e30 318i Touring Lux
Users browsing this forum: No registered users and 106 guests
