im looking for a spray on cleaner to remove the usual grime off a set of bike engine casings after a layup. Engine will remain in place whilst I clean it..
Any ideas?
Alloy cleaner
Re: Alloy cleaner
Foamy gunk did an amazing job cleaning the crud from my aluminium intake manifold. I did attack it with an old washing up brush before hosing the crud off.
Re: Alloy cleaner
Ah, I have some of that, was thinking of trying alloy wheel cleaner ?TerryG wrote:Foamy gunk did an amazing job cleaning the crud from my aluminium intake manifold. I did attack it with an old washing up brush before hosing the crud off.
Re: Alloy cleaner
Depending on what I'm cleaning it's either "Foamy Gunk" of Auto Glym Machine cleaner.
Re: Alloy cleaner
We use an acid based cleaner. It removes the aluminium surface oxide but does require gloves, goggles and a protective apron. There is still a fair amount of scrubbing required. If it shifts the dull finish and leaves it shiny bright in one go it will have the opposite effect on the user! Foamy Gunk is a good safe alternative.
Users browsing this forum: No registered users and 51 guests
