peugeot
Re: peugeot
What is scrap worth a ton over there?
- Grumpy Northener
Re: peugeot
Looking at that block work in your barn Rich - what type of bond is that then ? (obviously a non cement stack them on top of each other and hope they don't fall over bond by any chance?)
Re: peugeot
thats my pile of blocks that were stacked against the wall... honestGrumpy Northener wrote:Looking at that block work in your barn Rich - what type of bond is that then ? (obviously a non cement stack them on top of each other and hope they don't fall over bond by any chance?)
Re: peugeot
Potential solution for the car issue then. stack the blocks up next to it and wait for a strong gust of wind.....
Re: peugeot
update.... ive started taking it apart & the clutch is hydraulic & the bar that connects the pedal to the cylinder is bent & broken... im waiting for a copy of how to strip & refit everything.. nothing available on the net.. its the 110. the owner is thinking of scrapping it...
Re: peugeot
So is the clutch problem down to having a bent rod? that would be a really cheap fix.
Re: peugeot
i wish! the thrust bearing is going on the clutch & the rod assembly had seized/broke on the pedal
Re: peugeot
If I hold my clutch 2/3 of the way down it starts sounding like a dry bearing. If this one isn't fully disengaging is it the same effect?
Re: peugeot
the chap has decided to scrap it...he has enough trouble on his plate with a psychotic ex wife who's causing no end of problems.. i really feel sorry for the guy..
Users browsing this forum: No registered users and 118 guests
