Wobbly calipers.
Wobbly calipers.
#1 Post by Dick » Tue Jun 13, 2023 7:19 pm
Hi chaps, my old galaxy suffered with wobbly calipers clio was the same, now the 206 is the same.. 80,000 km from new.. what could be causing this?
Re: Wobbly calipers.
#2 Post by Luxobarge » Wed Jun 14, 2023 9:42 am
Wobbly in what way? Which bit is "wobbling" ? Need more detail mate!
What type of calipers are they (by which I mean do they slide on stainless steel pins i.e. single piston type or are they fixed solid to the caliper carrier and have double pistons) - pics would help!
#3 Post by Dick » Wed Jun 14, 2023 2:31 pm
They are on pins, im not able to post pics ... ive just been to my parts supplier and a repair kit isn't available..
#4 Post by Dick » Wed Jun 14, 2023 8:27 pm
After a bit of Internet searching and advice from my parts supplier I've ordered a repair kit...
#5 Post by Dick » Sun Jun 25, 2023 7:35 pm
Parts arrived last week so I spent most of the afternoon swearing at the brakes, what idiot designed that?? First problem one of the slide pins is screwed into the caliper tried 13 mm spanner too small 14 mm too big. Tried all the spanners in the box and nothing fitted.. pliers and more swearing plus trapped fingers got it out .. Clean everything up new disc and then pads.. what a ball ache that was.. tiny clips on the pad wouldn't go onto the carrier.. remove carrier Clean with wire brush head on the grinder and it still won't fit..cue more cursing the french, finally got them to fit with some persuasion from Mr hammer.. pop the carrier back on lots of copper grease wheel on and start again with the other side. The only difference was I had further to walk to the bench so more time to curse peugeot and the french.... test drive and the brakes work.
#6 Post by gazza82 » Sun Jun 25, 2023 11:26 pm
... what idiot designed that?? ...
Probably the same idiot that put the engine so far to the left that to change a cam belt costs you layers of skin and pints of valuable red stuff!!
#7 Post by Dick » Tue Jun 27, 2023 6:47 pm
Sounds about right, I'll get someone else to change that then, thanks for the heads up :thumbs:
sierra3dr
#8 Post by sierra3dr » Thu Aug 31, 2023 2:55 pm
:lol: :lol: not forgetting that the engine might be further back practically under the windscreen :mrgreen:
Users browsing this forum: No registered users and 127 guests
