clio diesel
Re: clio diesel
well funny you should say that, i have been coveting one of my clients modern datsun which has been sat in his shed for several years.. i may even make a cheeky offer on it soon.. even if it might cause wifey to have a meltdown & kick me out
meanwhile in the land of clio, after much swearing at stupid turbo pipes & loss of even more skin, the starter has been refitted, tested & seems to be working. i even reset the clock & put the code into the radio
Re: clio diesel
Well done mate, I'd have set it afire or weighed the thing in!
How modern is the Datsun?Sir Lionel Seldom-Upright wrote:"Thou shalt not covet thy neighbour's Datsun, but his wife's fair game."
Re: clio diesel
2004 lhd american import.. his wife is getting on a bit & is rarely in good humour..i will stick with coveting the datsun thanks
Re: clio diesel
started clio last night, & guess what, new relay jammed & starter was spinning on its own.. in the time it took me to find an 8mm spanner to disconnect the battery smoke was pouring out from under the bonnet.. still i can get the thing off in under an hour now!
off to see mr tarcelin shortly
Re: clio diesel
If ever there was a car that tried to tell its owner something, then this must be it! The thing clearly wants to die in flames. Let it happen and move on..
Re: clio diesel
You don't have much luck with automotive electronics Rich. Maybe it's time to hang up your spanners and use a gallon of unleaded and a match to solve all the cars issues
Re: clio diesel
thanks chaps!!
i hate car electrics!! they tested the original& it worked i have fitted a brand new one to test if its the car or the starter... i can fit one in record time now but with the usual amount of blood loss...found myself looking longingly at one of these yesterday..
https://www.leboncoin.fr/voitures/11432 ... tm?ca=18_s
Re: clio diesel
You've been papped going about your daily business while the clio is out of action:
Re: clio diesel
sorry terry, that cannot be me.. bicycles are against my religion...
Re: clio diesel
That's Frank Spencer's French cousin, isn't it?
Users browsing this forum: No registered users and 31 guests
