Ford Sierra Sapphire Restoration
Re: Ford Sierra Sapphire Restoration
All above posts updated above with latest pics, as of now we still got to weld on new sills, repair rust on boot catch area and fit new screen, elsewhere the stripped out interior is being cleaned and new headlining prepared, sunroof will need attention.
Will update as project goes on ........
New heated screen fitted today(Friday), welding work now complete and car coming back Saturday for fitting most of interior and door internals, MOT end of next week
New Heated Screen Ford Sierra by Mark Handley, on Flickr
The differential was noisy on my Sierra before it was laid up so time to get it sorted, once removed I drove it over to Bara Motorsport in Bromsgrove near Birmingham, it's a 250 mile round trip but they come highly recommended, I had arranged to drop it off at 9am and should be done by 2pm which it was.
Cant recommend these guys enough, Diff was stripped cleaned and reconditioned with new seals and bearings and properly set up.
Untitled by Mark Handley, on Flickr
Website here;
http://www.baramotorsports.com/" onclick="window.open(this.href);return false;
Website here;
That's all for now,
All the above has been imported from another forum and work has moved on since then, The diffs now fitted the car's mot'd and taxed, and has done about 100 road miles "Testing" and it drives really nice,
Headlining and C pillars have been restored with new material but not fitted yet a tricky job to say the least, but pleased with result
The newly welded floor has been seam sealed and painted, sound deadening, underlay and carpet back in and the driver's seat fitted
Other bits not mentioned, a new idle control valve fitted which cured idle surging
New Ford heater blower resistor fitted but heater blower still wont work, got to come out
Will update soon with new / latest pics.
Well done. Probably about time these got some proper love and attention.
P45.
P45.
My last Sierra was a Sapphire 1.8LX (G580 FVH) which had the CVH engine. Mine burnt a lot of oil which was down to worn piston rings. I'd had the valve stem oil seals replaced which didn't make any difference. The DOHC engine is one of the better Ford engines. Yours should have the MT75 gearbox which is light years ahead of the trusty Type 9.
Toledo Man
1995 BMW 318i (M265 PNC)
Wow! I enjoyed reading this. I'm just finishing off my Sierra,I'm using a Galaxy 2.3 block with a 4wd set up. So I had to weld in the 4wd tunnel,and weld in new metal in the same location as yours.
hi everyone
im new on here so please be gentle;)
i have a sapphire cosworth 1989 2wd, in need of some new sills among other things, i need the whole sills replacing left and right, does anyone know where i may source these parts from as at the moment there like hens teeth to get
07419 746 493
many thanks
steve
07419 746 493
many thanks
steve
hi everyone
also a t5 bell housing is required urgently if anyone knows of one
thanks in advance
thanks in advance
Users browsing this forum: Bing [Bot] and 167 guests
