Useless(new) Spare parts
Useless spare parts. Can anyone suggest a reliable supplier for an o/d switch(top of gear lever) for my MGB, have tried two from different sources and both faulty.Cannot see one on MGOC.
Re: Useless(new) Spare parts
I suggested three the first time you posted this question.. But, as the car is a 1967 example, the o/d switch should be a toggle on the dashboard, the stalk on the column came along in 1970ish, at around the time that the original chrome slatted grille gave way to the recessed black one, and finally, the slide switch on the knob only found its way from Triumphs to MGBs shortly after rubber bumpers. So either someone figured that making it necessary to remove a hand from the wheel to engage overdrive was a good idea and changed the knob and the gear lever for a hollow one, or the car is newer than you thought it was?
Apologies for asking the obvious, but have you checked that the wiring actually comes up through the lever? It should come up behind the speaker grille straight to the original location in the dash, maybe it's only the knob that is "wrong" for the year?
The switches I posted in the other thread are correct for a 1967 car.
Hi John, sorry for confusion, this query relates to my `78 MGB,not my older one,so it is the gear lever switch I am asking about .Ron
OK, so to save us quoting sources that you've already tried can you tell us where you got the two faulty ones?
Even with the well-known carp quality of aftermarket spares these days it's unusual to have two faulty ones, so John's comments about making sure that the wiring going up the gear lever is sound is a good call - make sure this is absolutely spot on, and if you think the switch is faulty then prove it with a meter off the car.
Cheers!
Cheers!
Hi again, yes had wiring checked (by garage) when wiring was renewed after burn out! They also checked switch.One switch was purchased on e-bay, but can`t remember who supplied it .The other was from MGB Hive (cash refunded very quickly).
Ron
Ron
Ah! My error then and you're not the one who should apologise, that'll be me.. Again! I must have misread something somewhere. I blame climate change..
These slide switches tend to be less durable than the older types but whether this is down to extraordinarily bad luck, or ageing to the insulation where the wiring rises through the lever, this shouldn't be too difficult to sort. I've seen more than a handful of cars with gearknob-mounted o/d switches where the constant flexing and heat from the underside has caused insulation to crack and in some cases, the wire itself will then fail or short against the inside of the lever. I'm thinking that the o/d switch as found in Triumphs is likely to be the same part and as such, James Paddock - a consistently reliable supplier in my experience - may be worth a call but definitely check that wiring and maybe run some fresh, silicon insulated stuff of the modern type up the lever for future reliabllity.
Does this look familiar?..
http://www.jamespaddock.co.uk/gearlever ... e-switch-4
If it the same as the Triumph ones try T.D. Fitchett as well.
Toledo Man
1995 BMW 318i (M265 PNC)
Thanks again, yes garage checked wiring and fitted line fuse to circuit on o/d because there was not one apparently, also "heat tubed" the wiring up to switch,will try suggestion of suppliers, sorry again for confusion, I know all about"climate change" in my case it is "age" change.
Ron
Ron
Users browsing this forum: No registered users and 112 guests
