'Zeb' - (Not a Classic) Bloggy!
Re: 'Zeb' - (Not a Classic) Bloggy!
Paul - go with it, sounds like it'll be just fine. I should have kept quiet - I just didn't know they did a one-size-fits-all, however it's not a bad idea as I guess it keeps production costs down.
John - no, the coolant capacity would be just the same, the black bit on the end will be mainly air instead of transmission fluid, that's all.
Cheers!
Cheers!
- Paul240480
- Contact:
Well, I went for it this afternoon. All running and back together. About 4 hours with a grub break . Got a little to do tomorrow, final topping up and the engine front under guard. Ran out of light!
Started with a 'dribble'
Even the old jubilee clips came undone, after an overnight soak
My method of supporting the air con condenser using a block of wood and some thin tongue and groove. Also shows supporting the rad itself using a jack and further piece of wood. Used the 'jack method' to fit the new radiator too.
All out, used two bits of wire to stop the top of the condenser wobbling in the wind
Finally running, temp gauge spot on 3 O'clock and fan cut in. Computer and clock out of kilter, as disconnected battery during work.
Paul240480
Nice one Paul - well done. Not a bad job is it?
Cheers!
Cheers!
- Paul240480
- Contact:
Thanks . No not too bad. Top bolts on air con compreser most difficult , having a mini 'wobbly' to fit a socket to the 8 or 10 mm bolts was a good moment!Luxobarge wrote:Nice one Paul - well done. Not a bad job is it?
Cheers!
Paul240480
Oh! Did mine without having to touch that....??Paul240480 wrote:Thanks . No not too bad. Top bolts on air con compreser most difficult , having a mini 'wobbly' to fit a socket to the 8 or 10 mm bolts was a good moment!Luxobarge wrote:Nice one Paul - well done. Not a bad job is it?
Cheers!
- Paul240480
- Contact:
Luxobarge wrote:Oh! Did mine without having to touch that....??Paul240480 wrote:Thanks . No not too bad. Top bolts on air con compreser most difficult , having a mini 'wobbly' to fit a socket to the 8 or 10 mm bolts was a good moment!Luxobarge wrote:Nice one Paul - well done. Not a bad job is it?
Cheers!
Ahhh! Despite having read up , I had my Haynes manual out there with me.... Nuff said!
Paul240480
who do you get your classics insurance with?
I'm not pretending for one moment that my V70 is a classic, but Peter Best are happy to insure it as one - fully comp with agreed value, under £180 last year. Limited miles of 5,000 but that's no problem for me - I don't get out much....rich. wrote:who do you get your classics insurance with?
- Paul240480
- Contact:
Went to finally top up the coolant this morning after nights cooling down. I managed to sort a fix (bodge ) for two bolts & clips that had disintegrated at the top of the rad & replaced the front splash tray underneath.
Then went for a 15 or so mile spin including a short blat up the due carriageway. Coolant temp was bang on and level bang on also, no drips so far either.
As far as insurance goes mine are with Axa, though don't forget, in France
I pay about 28€ a month for Zeb. Thats not on classic, set value of 1500€
My 'soon to be V70 (2004) is going to be 30,24€ a month,again not classic & set value 3500€ (I'm paying £1500 )
Tank 240 is going over to assurance voiture d'collection (and, of course it is arguable as to wether a 240 is a classic) will be 10,68€ a month with 'market value' (that'll be peanuts then )
Paul240480
Is that not a wee bit, erm, naughty? Just as well that representatives of the motor insurance industry never, ever read classic car fora isn't it.
Users browsing this forum: No registered users and 44 guests
