Hampshire / New forest area?
Know of a good garage, mechanic, sprayer, supplier in your area? Why not post their details here. Please only post if you have actually used and received good service from this person or place AS A CUSTOMER. Also if you can put the area in the title that will be helpful - when we have enough we'll separate them into Counties / Shires. Note: this is for private members' recommendations, NOT owner/proprietors to punt their businesses - these will be removed.
colin1f
#1 Post by colin1f » Tue Oct 22, 2013 1:24 pm
Hi all,
Have just moved house..can anyone recommend a good classic friendly garage in Hythe / Totton / Southampton/ Brockenhurst type area?
Don't need it yet but you never know!
Cheers all
col
Re: Hampshire / New forest area?
#2 Post by mach1rob » Wed Oct 30, 2013 1:59 pm
Might be a bit far out, right on far edge of the Forest, but I can highly recommend Steve and the rest of the lads at Sopley. It's the only place I use, and I happily trust them with both the classic and moderns for the MOT and jobs I can't be bothered to do. If it helps, it's about 10 mins away from Burley, which is about 10-15 mins from Brock if that helps with distance time scales :)
http://www.sopleygarage.co.uk/
colin1f
#3 Post by colin1f » Tue Nov 05, 2013 9:55 am
Hi Mach1Rob
Many thanks for both bits of info you posted.
cheers col
#4 Post by mach1rob » Tue Nov 05, 2013 1:56 pm
Welcome :)
