Antifreze
We're back!
GMC keith
Antifreze
#1 Post by GMC keith » Mon Oct 29, 2012 6:26 pm
Hi Hope some one can hellp ,i seam to rember that PC did an artical about antifreze,but cant rember what they recomended for older engines such as my 1979 GMC . Can any one help .
Regards Keith
Re: Antifreze
#2 Post by suffolkpete » Tue Oct 30, 2012 9:42 am
Copied to Technical Queries
Re: Antifreze
#3 Post by Luxobarge » Tue Oct 30, 2012 9:58 am
Just use more of whatever is in there at the moment.
If it's blue, use standard blue antifreeze. If it's red, use red long-life antifreeze.
Either will work just fine, but DON'T mix them, or your system will end up consisting of sloppy goo that will need to be flushed out.
Cheers :D
alabbasi
Re: Antifreze
#4 Post by alabbasi » Sat Nov 03, 2012 6:49 am
Any anti freeze will be fine, just stick some in there. If it's the green stuff, change it every couple of years. If it's yellow, blue or red, it's long life and will last longer.
sierra3dr
Re: Antifreze
#5 Post by sierra3dr » Wed Jun 19, 2013 10:49 am
jpsh120
Re: Antifreze
#6 Post by jpsh120 » Wed Jun 19, 2013 12:10 pm
Any MEG antifreeze is generally advised. I bought THIS for mine.
1971 Sunbeam Rapier H120
Ian
Re: Antifreze
#7 Post by Ian » Sun Jun 23, 2013 7:12 pm
We sell Evans Waterless coolant. Never needs changing. Many of our customers ask for it as it eliminates boil over and inhibits corrosion, its really good stuff but even when hot you can take the radiator cap off with no drama (no water, therefore no pressure)
Re: Antifreze
#8 Post by TerryG » Sun Jun 23, 2013 8:18 pm
I've seen various of those. I am always loathed to spend that much no it as whenever I have to do work on the car that involves anything to do with cooling I always end up spilling some and what ends up in the bucket under the car is always contaminated with the oil / pas fluid that acts as a rust inhibitor on the chassis.
sierra3dr
Re: Antifreze
#9 Post by sierra3dr » Wed Jul 03, 2013 11:57 pm
I was reading the other day that tap water isn't ideal,because the parts become coated with minerals
Users browsing this forum: No registered users and 69 guests
