So far, I have checked the ignition timing which is spot on (Was popping back through the carbs and spitting flames from the tail pipe), carried out a compression test which reveals 90,90,90,100,110,100, 95,100 which seem really low to me but surely this wouldn't cause the engine to just stop?
New Distributor cap and rotor arm (Has electronic ignition so no points / condenser etc) new high quality ignition leads, replacement of the original fuel pump with a facet pump, checked the diaphragms in the strombergs which are brand new, carbs have been rebuilt, new high quality ignition coil ( have also tried earthing the coil bracket as had a similar issue with my Scimitar) New fuel filter, new NGK spark plugs ( I believe some classics run better on Champions? )
Today while adjusting the timing I had a zap from the distributor (Dizzy itself is brand new) this happened several times despite being the second new cap, rotor arm and leads, I have tried bypassing the fuel inertia switch too but nothing seems to make a difference, please please please someone HELP
