I'm changing the oil in a 5 speed Type 9 gearbox (think Capri), but I can't find the right oil either.
The Haynes manual says on the 4 speed box to use hypoid gear oil SAE 80EP which is in my local factors no problem. For the 5 speed it says to use semi synthetic hypoid gear oil 75W/90S, not the EP. Problem is I can only source semi synthetic 75W/90 in EP variant.
Anyone care to explain what the difference is and why I can't use EP? From there any suggestions what oil to use would be appreciated?
Thanks in advance.
Another gear oil question like s-type...
1971 Ford Cortina 1.6L
1979 Ford Cortina 2.0GL
1984 Ford Capri 2.8i
1985 Ford Transit 100 AutoSleeper
Re: Another gear oil question like s-type...
Sounds like time PC did an article on gear oils like the excellent one you did on engine oils a few months ago
- 1275midget
I've got EP90 in my type 9. GL5 eats copper things, which is why it shouldn't go in some diffs (spitfires I think)
there should be no problem with the Extreme Pressure stuff, If a standard midget gearbox can survive on 20-50 engine oil then EP/non EP oil may not make a lot of difference.
When was EP invented - possibly after some manufacturers could spec. it?
Unless it categorically says don't use it (like for a spitfire diff), I'm pretty sure it would be OK.
1.4 K series Midget. Bwaahahaha lunacy. www.robsmidget.com
1968 Series 2A. Lunacy of a more sedate variety.
Users browsing this forum: No registered users and 104 guests
