When I had a 205, the resistor went open circuit and all that happened was that the dim-dip stopped working and the lights functioned normally. That was why I suggested disconnecting it. Your version seems much more complicated.It does not make any difference if the resistor is connected or not so that can be ignored.
Citroen dim dip headlamp wiring diagram.
Re: Citroen dim dip headlamp wiring diagram.
Hi Suffolkpete no problem, it can only be a Citroen they do seem to do things in a rather convoluted way, you know that is what I thought, remove resistor sorted.Ha Ha.I should have known. Cheers mate.
Geoff.
Geoff.
Tell me about it! My daily drive is a C5
suffolkpete wrote:Tell me about it! My daily drive is a C5
Yeah, you must be to drive that on a daily basis, respect due to you though, I wouldn't have the cahones for it.
Users browsing this forum: No registered users and 84 guests
