ACCUSPARK IGNITION HELP!
Just wondering if anyone has any experience of fitting one of these onto a Rover V8 or the like, seems like a pretty good kit but instuctions could be a bit better unless its me. I believe i've purchased the correct kit, a 35D8 which is stamped onto side of dizzie body but cant seem to work out where it screws onto the dizzie plate.
- TriumphDriver
Re: ACCUSPARK IGNITION HELP!
I bought one for the Delco distributor on my Triumph last month; the instructions say it uses the condenser and backplate screws to fit. Remove the points and rotor arm and rotate the electronic unit around the backplate until it lines up with mounting screws and chances are they're the ones to use. Some of them also use one screw only; the other support is the small pin the points slot over.
Users browsing this forum: No registered users and 3 guests
