spraying
Re: spraying
got some antibloom, tried again, room was warm,but had the same result. Tried changing the psi, mixture, but still not much better.
Re: spraying
There are a few causes. Firstly, what ratio are you using? The recommendation is 50\50 but you might like to try making it thinner. A viscosity gauge is useful for this.
Are you using the recommended pressure for your gun?
What tip and needle are you using and what type of gun is it? LVLP, HVLP etc.
What is the ambient temperature that you are spraying in?
Re: spraying
many thanks .
using 50/50 with anti bloom
not sure its a fmt4001g fast mover
1.3 conventional gun
electric heater at least 18c
Re: spraying
OK with that gun and needle, you should have just over 20psi with the trigger pulled. Make sure your gun gauge gives that reading WITH THE TRIGGER PULLED AND PASSING AIR. Then thin your paint to 60 percent thinners, try up to 75 percent, although that weak is normally only used for final coat. Bear in mind that the more you thin it, the more likely it is that you will get runs.
Are you setting the gun up on a test surface? You should be holding the gun about 6 inches from the panel, with a fan size of about the same. Adjust the material control to give you a nice vertical pattern that is not centre or top/bottom heavy. If you are getting orange peel, keep the material control set at just enough, if you go too far with it, then orange peel will result.
Re: spraying
The other point of note with that gun is to set the air throttle correctly. It should be in about the centre of its travel. Easy to check, pull the trigger and adjust for maximum depression. Then leave it alone and set the pressure at the compressor regulator.
Re: spraying
finally I got it right ,well least I think so ,a bit of orange peel but much much better ,many thanks ![Thumbs Up :thumbs:](./images/smilies/icon_thumbup.gif)
Users browsing this forum: No registered users and 12 guests
