'ello,
I have had a look at the problem with notifications a couple of times and can't find anything obviously wrong with it. It is certainly not working but it is going to take more time than I have spare at the moment to find the cause of the problem.
I would assume the fault was introduced when upgrading the forum to the latest version of the software.
When I get a spare few hours I will compare a backup to the current version and see what has changed then possibly reverse the changes to that feature.
Regarding the time of posts that is controlled by the server operator. they "should" have the clock set to GMT but obviously run it on local time. That's the problem with windows servers.
I'm used to them being out by an hour so tend to just ignore it. When we find a new host hopefully this issue will disappear.
No notification
Re: No notification
Re: No notification
Are you you guys working on this by any chance? I have just got a notification from another post I have subscribed to last on May the 17th
Users browsing this forum: No registered users and 84 guests
