#3451
Post
by Dick » Mon Apr 12, 2021 5:36 pm
JPB wrote: ↑Mon Apr 12, 2021 4:51 pm
GHT wrote: ↑Sun Apr 11, 2021 10:24 am
...if you still have an old Cortina knocking about somewhere.........................
... then I would tax it, insure it, get it through its MOT and use it! The Cortina has a roof, so that's very unlikely to leak (that's the job of the windscreen rubber and some hidden rust in the scuttle) and it's a Ford, so someone would always want it if I and the car failed to bond!
Meanwhile:
https://www.ebay.co.uk/itm/1998-Land-Ro ... 1438.l2649
It's a "truck" that may,
break down, so does that count or have I forgotten the rules of this thread?
And no, I'm not looking for another, not in the UK at any rate.
I'll have to try and explain the rules of the game..
1 pass
2 any random shinyishthing that takes your fancy
3 are there any rules? If there is please let me know
4 welcome back mate....
#3452
Post
by GHT » Tue Apr 13, 2021 7:24 am
Don't forget that Cortina's suffer from McPhereson Struttitis. The metal above the struts is not only paper thin but the underside has no protection from everything that the wheel picks up and throws at it. Before too long the strut pops up through the bodywork, and if you are really unlucky, through the bonnet too.
And where do you think that you have been. I shall be expecting to see a note from your Mum explaining your absence.
#3453
Post
by suffolkpete » Tue Apr 13, 2021 9:06 am
He probably thinks the McPherson Strut is a Scottish country dance
#3454
Post
by Dick » Tue Apr 13, 2021 9:22 am
suffolkpete wrote: ↑Tue Apr 13, 2021 9:06 am
Ght as an accomplished dancing type, you should be able to demonstrate the McPherson strut for us..
#3455
Post
by JPB » Tue Apr 13, 2021 11:05 am
Only some Cortinas have struts. MK1 and MK2 models used these, with trap springs at the rear. Later MK3, 4 and 4 Facelift Cortinas had double wishbones up front and coils all round, the load on the fronts being borne by a separate crossmember.. Suspiciously similar to the one used in Spartans after they ceased to fit the Triumph derived setup with a brass trunnion instead of a lower ball joint at the lower end of the hub carrier.
A two door MK3 - in an orange so violent that anyone looking directly at it would be risking their eyesight - is my choice of Spartan alternative from available Cortinas.
GHT wrote: ↑Tue Apr 13, 2021 7:24 am
....I shall be expecting to see a note from your Mum explaining your absence.
Bring your own shovel if you want that note, she's been vertically socially distanced since May 18th 2016.
#3456
Post
by GHT » Tue Apr 13, 2021 10:30 pm
My feeble attempt at jest truly backfired there John. Sorry about that, my condolences, I personally know that particular bereavement.
#3457
Post
by JPB » Wed Apr 14, 2021 2:51 am
#3458
Post
by GHT » Wed Apr 14, 2021 7:05 am
- military-truck-tiny-house.jpg (212.88 KiB) Viewed 1617 times
You should get yourself along to The Goodwood Revival and see some of the military truck conversions.
Apart from the cost, how people arrange parking, storage, garaging and servicing blows me away.
Not everyone lives on a farm, do they?
#3459
Post
by GHT » Wed Apr 14, 2021 8:22 pm
Dick wrote: ↑Tue Apr 13, 2021 9:22 am
Perhaps I should look it up and then demonstrate it. Just one concern though. Do I have to do it in a kilt?
#3460
Post
by Dick » Thu Apr 15, 2021 9:03 am
GHT wrote: ↑Wed Apr 14, 2021 8:22 pm
We expect nothing less!
Users browsing this forum: No registered users and 136 guests
