oxidized iron
oxidized iron
as we know is rust. Some interesting convertors/inhibitors
http://www.fertan.co.uk/
http://performance-chemicals.net/vactan/
http://flagpaints.co.uk/product-browser ... -converter
Since I cannot find my fertan,buried in my workshop somewhere. So I'm going to give the Flag a bash
Please add if you know others
Re: oxidized iron
Bilt Hamber DEOX-C and DEOX-GEL, and Hydrate 80 and in full time use in my garage
http://www.bilthamber.com/corrosion-pro ... treatments
Re: oxidized iron
i have used cold galvanising paint in the past.. not for cars but its been quite effective..
Re: oxidized iron
Not having salt on the roads helps, but it's getting harder to avoid areas that do use the evil stuff these days.
Of course there are other potential - and usually climatic - causes of premature corrosion such as living by the sea and running a car made from the sh*te Russian steel that spelt death to so many Alfas (and BL things of certain periods), which is why I have always had good results with Shell Ensis (V and other recipes). Its use when the car was new is most likely the reason that I currently own a completely rust free, 25 year old Toyota and whenever I've been the first to apply anything to one of my cars, the Ensis has worked then too. The one car whose rot caught me unawares (when a potential buyer found it! ) was one of the Reliant Rebels and that had been dosed with Waxoyl since new, when the supplying dealer had injected every single part of the car's chassis, its body frame and the underside of all of its wooden parts. That car taught me that a) Waxoyl is rubbish if applied to things that were built from steel intended to flash rust before being coated with the epoxy primer used by the likes of Reliant and Noble, and that b) Waxoyl is really good for wooden things , the rear floor of that Rebel was as fresh as a daisy in spite of the fact that there was rust in one of its 16swg tubular sections, a section that had been capped, filled with the famously smelly Prudhoe-made mixture of cheese and silage**, then capped and sealed at the other end.
I have the invoice showing that the original keeper of the AE92 spent £240 on Ensis treatment and, even now, some twenty five years on, the coating is still capable of healing when it takes a hit from a small stone or similar.
** - well go on, what else could it be made from? Certainly nothing that wants to remain attached to steel, paint or light surface corrosion, beyond these things, what use is the stuff? Oh wait, Chipperite is made in the same plant! 'I remember when that used to work..
Re: oxidized iron
The gumption that turns rusty metal blue is also known as naval jelly. ( no not belly button fluff it doesn't work).
Rust is iron going home to its natural state. Mother nature.
Fortunately I live in Bournemouth Dorset and road gritters are very rare. About once every 5 years. I don't drive my car if tge roads are salted. When we do get snow by lunch its melted and then it rains whuch hooefully washes the salt off.
Try this just for enlightenment. Clean piece of steel and wet with salt water and leave for 24 hours.
Notice that where old cars have leaked oil the steel is not so rusty and even as good as new.
Bob.
Bob.
Re: oxidized iron
OK, steps one and two completed. Waiting..History wrote:..Clean piece of steel and wet with salt water and leave for 24 hours...
Re: oxidized iron
It will start to rust.
Bob.
Bob.
Re: oxidized iron
Good greif, really? History - do you not know what John is trying to say in his 3-picture post above?History wrote:It will start to rust.
Bob.
We're not stupid on here you know........
