ford granada mk2
We're back!
Badboy449
ford granada mk2
#1 Post by Badboy449 » Fri Jan 08, 2021 4:34 pm
Hj guys help needed i recently have had a engine rebuilt on my mk 2 granada 2.8 V6 on carb , right i have repainted under the bonnet , havnt cut anything put everything back in ( bar engine still not finished ) Cleaned all the earths had all fuses out to clean up , lights/interiour lights/stereo/indicators/wipers all work with ingintion on .... The ignition lights on the dash dont come on , the electric windows/electric seats/horn and heater wont work ...Please any help
Re: ford granada mk2
#2 Post by Dick » Fri Jan 08, 2021 7:58 pm
Silly question, have you reconnected the battery or starter?
#3 Post by JPB » Sun Jan 10, 2021 4:53 pm
I can't see how the courtesy lamps would go up only with the ignition on, or do they come up as normal without ignition on, and other items that should be supplied from the accessory or ignition switched live terminal of the barrel going off when the courtesy lamps come up?
Could you maybe post a video clip to your video hosting site of choice, so that we can see what's happening with and without the lamps?
Good luck.
