Page 7 of 12
Re: 'Tank' A 'Rolling Resto' Bloggy (of sorts)
Posted: Wed Aug 08, 2012 7:09 am
by Paul240480
So, then onto the dashboards lights:
1) Remove the dash.
2) Remove the guage console from the case & drill a lil' ole hole for the wires to exit:
3) Stick the run of LED's here:
Which makes them 'invisible' once the case is turned the right way up.
5) Refit the guages, the console & wire the LED's into a suitable feed. I used the clocks light live & earth. This means that they will come on with the day run lights as the old bulbs would.
Daytime pic:
Nightime pic 8-)
Posted: Wed Aug 29, 2012 11:27 am
by Paul240480
Once again I let the 'red' slip away from me. Hadn't really noticed until I saw another red one on another forum. Tank was pink :o :lol:
'He' was like this all over:
So I am starting to bring back the red 8-) Still got the nearside, tailgate and the roof to go.
So far:
I used :
1) Ecauto Shampoo
2) Clean Plus 'Lack Reiniger' (a 'paint restorer' which I guess is a 'cutting agent')
3) Ecauto Power Polish
Then after an hour or so,
4) Colonite 476
5) Linseed Oil on the 'black bits'
Posted: Wed Aug 29, 2012 1:50 pm
by arceye
Shiny :D
Red always seems to be a bugger as it ages, but that has fetched it back nicely.
Posted: Wed Aug 29, 2012 8:40 pm
by Paul240480
arceye wrote:Shiny :D
Thanks, still got a lot to do... But I am chuffed :D
Posted: Sun Sep 30, 2012 5:19 am
by Paul240480
Ever since replacing the cambelt and auxiliary belts, one of the alternator belts keeps somehow working loose & then starts squealing :twisted: Try as I might, I just couldn't get it to stay tight enough. In desparation, the other day when 'my' mobile mec' popped by I asked him to take a look. Straight away he said that the belts were the wrong size & were sitting too low in the pullies. He explained that it is the sides of v-belts were they 'grip' & that the teeth are there only to disperse crud & dust. The belts I'd fitted were 9.5mm pukker Volvo jobs.
Being me I had the old belts still. I got them out to find that they were 10mm! Contitech, ones I fitted in probably 2007.
So I contacted the Volvo parts supplier who confirmed that he had supplied the correct belts as Volvo only ever fitted the 9.5mm ones on 240's. There is no other Volvo option. He did though, kindly offer a refund if I wished.
I decided that I must try a set of 10mm, so have ordered some from GSF. They are on route.
Anyhoo' I was getting fed up with the squealing & yesterday I decided to refit the old Contitechs. Result was that both belts tightened & all is now quiet. The Conti's are not particularly badly worn, just past their 'sell by' date. So not in a major rush to fit the GSF ones, though I will do when I have a spare hour or so.
Here are the 9.5's just before removal: Image
And here the 10's fitted, you can see how much deeper the 9.5 sit in comparison: Image
Finally, the 9.5 Volvo ones after only say, 1000 miles : Image
Maybe the pullies become wider with wear, or was it because I fitted 10mm (supplied by Braydons Volvo Specialists) which have worn the pulley grooves wider :?: Funny though that all the aftermarket suppliers I tried supply only 10mm belts.
Posted: Fri Oct 12, 2012 12:04 pm
by Paul240480
MOT, well 2-yearly Controle-Technique this morning. Went straight through with a compliment on how good Tank is from M. Le Testeur!
Advisories:
1) DISQUE DE FREIN: Presence de corps gras (ARD ARG) Not sure on this as direct translation is "Rear Discs presence of a fatty body" :lol: - Will have to ask on the frenchy forum.
2) Play in steering wheel at full lock. Another weird one?
3) Minor play in steering rack
4) Dipped too low
5) Headlamp reflectors deteriorating ( Quelle surprise!)
6) Front tyres wearing very slightly on inner edges (he reckoned this tied in the play in steering rack).
7) Surface rust 'underneath rear'.
8) Battery not correctly fitted (checked on this one and that bit of plastic that 'locks' it in place has gone awol:lightning: .
9) Engine oil leak
10) Gearbox oil leak
11) Differential oil leak.
:D
Posted: Fri Oct 12, 2012 12:36 pm
by blades
Paul
Nice work on Tank, I haven't heard of linseed oil for the black plastic parts before, did you also use it on the bumpers
If so i will give this a try on my car
Nick
Posted: Fri Oct 12, 2012 12:43 pm
by Luxobarge
blades wrote:Paul
Nick
Yeah, peanut butter works too. Neither lasts for ever though.
Posted: Fri Oct 12, 2012 3:00 pm
by Paul240480
Thanks! Okay the presence of a fatty body, is some grease on the discs. Wether that's a leak of some sort.... Mind obviously not enough to make the brakes fail the test.
Yes the Linseed Oil was used on the bumpers too. I use it on the 850 too. I find it needs doing about twice or three times a year over here.
Posted: Mon Oct 15, 2012 12:36 pm
by blades
Cheers lads, i'll give the linseed oil a try
Nick
