Page 2 of 14
Posted: Wed Jan 20, 2021 10:29 pm
3xpendable said: "Well it's taken 5 years, but I'm back on the classic scene!"
Five years eh, and now you are back. Well let me tell you we want to see a note from your Mum explaining your absence. No forgeries now. And we want to see a blow by blow account of that 105E's tidy up. No excuses now and don't wimp off.
I shall be asking questions later.
Posted: Wed Jan 20, 2021 10:43 pm
by 3xpendable
Dick wrote: ↑Wed Jan 20, 2021 7:18 am
How much does shipping cost you?
Would be cheaper if it ran. Then I could put it on a RORO carrier and pay about £800. However as it doesn't drive it needs to go on a container so will be about £1600 plus some important fees.
Still a lot cheaper than buying one here.
Posted: Wed Jan 20, 2021 10:44 pm
by 3xpendable
GHT wrote: ↑Wed Jan 20, 2021 10:29 pm
Yes sir
Posted: Thu Jan 21, 2021 7:47 am
by Dick
Ght wins the internet..
. 3xpendable 5 years... did you kidnap terry??
Posted: Fri Jan 29, 2021 2:58 pm
by 3xpendable
I didn't
Not much news at the moment. I'm busy organising shipping and also procuring parts as the 105E owners club wont ship parts to the US. I have decided to just replace all the service items and all the brake components.
I also bought an MPH odometer off eBay, along with some bits of trim missing and the heater blow switch.
Posted: Fri Jan 29, 2021 7:37 pm
by Dick
Can you get someone to fill the boot with spares before it leaves the uk ?
Posted: Sun Jan 31, 2021 12:10 am
by 3xpendable
No, cars have to be empty when shipped. However I can add a box of parts on a pallet so am doing that.
Posted: Wed Feb 03, 2021 12:51 am
by 3xpendable
Well, shipping is no provisionally booked for June 12th! So I should receive it later that month. In the meantime my brother and dad started looking over it today to see what it needs to get running. I have a new stainless exhaust system being sent there next week for starters.
In the meantime, there was a lot of dirt and dry matter under the rocker cover!
It all hoovered up just fine I'm told, and was pretty clean otherwise.
When my dad got it in 2014 it did turn over but wouldnt today, so diesel has been left in the bores for a few days and it should free up.
Magic eye time!
Bores look good, but those eagle eyed will see that both valves are open on cylinder 3. Hopefully a persuasive tap on the top of the valve stem will free it off.
Fuel tank is empty with some residual gunk in there:
It's rust free though which is good. I'm looking at the best ways to clean it out. I;ve read putting a load of marbles in there to agitate dirt, then washing it with water and cleaner does the trick but I'm all ears.
Finally, the underneath looks solid with one 2 small patches that need welding.
Posted: Wed Feb 03, 2021 8:45 am
by Luxobarge
I used gravel in the tank on my Midget, shake it around a lot and it cleans it pretty well - it's REALLY hard work to shake it though, with all the weight. Marbles wouldn't be abrasive enough I would have thought. IIRC I then flushed all the muck out with soapy water and then a hose. I dried it by removing the sender plate and poking a hairdryer in there for a few hours on a gentle setting - worked fine.
Posted: Wed Feb 03, 2021 10:41 pm
by 3xpendable
Luxobarge wrote: ↑Wed Feb 03, 2021 8:45 am
Thanks LB. I'll consider that.
I was told today that it was discovered that the rocker shaft was seized. When that was removed all the valves closed easily. Therefore they are now leaving the shaft in soak and will dismantle/clean it up. The diesel in the bores also worked, engine now turns over!
