Posted: Mon Nov 23, 2020 10:37 pm
All I've generally needed so far are normal service items, so it's mainly just been been British Parts. For anything more involved, Rock Auto over in the US have somewhat to my surprise been both the cheapest and have generally got stuff to me faster than most UK based suppliers.
Decided it had been far too long since TPA had been out. Had intended to get her out last week but torrential rain ended up putting paid to that plan, mainly on account of the windscreen demister being pretty much useless. Issue is basically that because the duct is so long and narrow there just isn't enough airflow. The heater really needs a decent blower which can both shift a decent volume of air and also produce decent static pressure so it doesn't just get choked by the ductwork. That was the issue I had with the axial blower I tried originally...it shifted masses of air in the open but couldn't handle the back pressure from the heat exchanger and all the ducting.
It was obvious on start up that she wasn't happy. Just wouldn't idle properly, no matter what I did. Felt more like an ignition than fuelling issue to me so decided to go over the basics.
Gave the distributor cap a wipe down and the contacts a scrub up.
Wasn't terrible but equally could be better. Given this is the cap which came with KPL and spent goodness knows how long open to the weather I really should just change it...
The rotor arm looked fine so just gave it a very gentle clean. That's not a dark spot by the way, there's just a polished spot where the centre contact sits and it's reflecting shadows.
Pretty sure dirty points were to blame as there was a bit of oxidisation present. Gap was fine though once the contact surfaces had been given some attention with some fine Emery cloth.
While I was in the area I changed the somewhat ropey crimp terminal on the switched line from the coil.
I have previously noted that I could stall the engine by wiggling that wire before so had been meaning to change it for a while.
I did note when testing that there's a bit more of an arc at the points as they open than I'd like. So I reckon the condenser is on the way out. May well be behind the original issues today.
Given how terrible the quality of most automotive replacements these days I'm not even going to bother with them. These condensers almost always seem to be in the 0.1-0.3uF range that I've seen values stamped on, so as I've got good quality polyester film caps in stock in 0.22uF/1kV I'll just be fitting one of these.
I will probably gut the can of the original and stick it in there so it'll be a nearly invisible upgrade. This cap should essentially be a fit and forget solution as these caps don't tend to degrade appreciably and damp doesn't affect them as they're properly hermetically sealed.
I still keep expecting this engine to use oil for no really valid reason and it keeps surprising me when the oil level never moves.
With the ignition system back together she started up first touch and idled properly again.
Reckon the points might have wanted a clean for a while as I'd swear it feels like we've got more low end torque now.
So off we went, first stop for the day was to pick up more dog food.
Then off to pick up a few other essentials in a few different locations around town.
Most of the travel between these locations wound up being straight up and down the A5 as town seemed to be really snarled up most of today for some reason. Sure I remember there being a time when "big" roads like that were something I generally tried to avoid wherever possible in this car...whereas now we're quite happy to use them and buzz along quite happily at a shade over 60. About 63 seems to be where she gets into a groove on roads like that for want of a better term.
Still find it somewhat amusing that the speed she hates doing the most is 30. To look at it you'd expect this to be most happily bumbling along at that sort of speed, not blasting along the open road at 60 plus change. The dissonance between the appearance and actual capabilities still makes my head spin a little and never ceases to amuse.
Glad to report that the adjustment of the nearside door front striker has both reduced the door rattle noticeably and has vastly reduced the draught which used to come in around the leading edge.
