Posted: Wed Oct 17, 2018 10:02 pm
The new crankshaft pulley for the Xantia arrived this morning. Comparing old and new it's pretty clear that the old one is well and truly knackered.
It's very clear that the outer edge has moved relative to the "hub" - the result of course being the belt being pulled out of line.
Swapping things out was literally a case of "de-tension belt, unbolt, remove pulley, put new pulley on, clean bolt, apply thread lock, tighten bolt, re-tension belt, tidy up."
Which was about the long and the short of it. It does appear to have resolved things for the most part. I've marked the pulley and bolt and will be keeping an eye on it to make sure it's staying bolted up before I put the wheel arch liner back in.
The oil leak - which looks massively worse here than it is - the car has never left so much as a single drip of oil where it's parked - is from the cam cover. I'll get it replaced at some point, though it's pretty well buried, so it may well be a while before it gets to the top of the to do list.
Tomorrow's task is probably going after this with a set of good quality hose clips.
I know that there's some air getting into the system, and the perpetual film of oil there tells me that one of the return hoses is weeping slightly...so hoping that going over things properly will resolve both of these issues.
Lastly I fixed this...
Which took me all of 30 seconds to get the screw out, remove dead battery, find replacement (2x CR2032) and put it back together again. So why on earth had I put it off since mid May when the remote stopped working?!?
