Re: Austin A30 Seven
Posted: Thu Sep 24, 2015 7:25 pm
Well, the eye is feeling a little better though still blurry, thanks tractorman for now making me think it might stay that way And, I must say that Landy of yours is going to be one of the better sorted examples by the time its done.
Anyway, I decided I'd avoid the welder but couldn't resist uncovering some of the next job, and thought it a good chance to actually show how the repairs have stacked up over the years.
Inside the boot and above the rear spring hanger / chassis leg you can make out a large flat plate "welded" (and I use the term loosely) to the boot floor, I've made it easier to spot by prying up a bit of an unwelded edge.
Underneath this plate, was.... another smaller plate and some holes
With that one removed there is another tacked in plate just to the side of it in the curvature of the upright
And so I removed that also
You can see in the photo below more plates to the inner arch area,
little to convince me they are of better quality I shall remove them in the next sitting, but for tonight I just shifted the axle stand away from this area I want to work on and for want of anywhere better to put it I shoved it under the rear of the boot floor edge, hopefully that, a scissor jack to the new sill, a trolley jack to the new rear spring hanger and a lump of railway sleeper under the car will keep it in the air for want of anywhere good to actually support it.
Theres going to be a fair bit of remaking to get everything right here, and while I'm at it I have this lot to sort
More Bodgery
So for tonight I thought I'd just use a bit more of Lidls finest rust proof paint to stop the good bits getting a flash of rust.
Lots to keep me busy anyway, guess I'll keep chopping out and then take it from there.
More Bodgery
