Page 2 of 2
Re: Short term Jag project
Posted: Mon Jan 27, 2014 8:08 am
by Grumpy Northener
Found time to drop the bumpers off the Jag - they are typical of a low mileage car that's been stored - a couple of minor dinks here and there but on car like this they stand out to me like a sore thumb !! To save cost & time I opted to straighten them up before sending them to the chromer
- WP_20140126_015-001.jpg (72.95 KiB) Viewed 1418 times
Damage like this was chased out from the rear then the high spots roughed out with a course file - then worked back with a finer file - P80's production paper & block - them P180's until I achieved this result
- WP_20140126_016-001.jpg (75.25 KiB) Viewed 1418 times
Difficult to see with the light reflection but will be great once rechromed - the parts dealers want £450 for a rear quarter bumper alone so this is well worth the effort - dinks to the front one piece and the rear section were also sorted
- WP_20140126_007-001.jpg (64.7 KiB) Viewed 1418 times
The mounting bracket on the front bumper had taken a knock at some stage and was out of line - I carefully cut through the welds with an airsaw - straightened the bracket up and shot blasted the surface rust off it before mig welding it back into situ
- WP_20140126_013-001.jpg (70.04 KiB) Viewed 1418 times
Posted: Mon Jan 27, 2014 8:18 am
by Grumpy Northener
The offside rear quarter only had one bolt through it when I came to remove it - someone had sheared the other at some stage
- WP_20140126_020-001.jpg (65.85 KiB) Viewed 1418 times
Both heat and a pair of mole grips failed so I opted to weld a bolt to what was remaining and that also failed to remove the stud - last option that did work was to drill the stud out and retap the captive nut
- WP_20140126_021-001.jpg (76.09 KiB) Viewed 1418 times
New bolts ready to go when it gets back from the chromer
- WP_20140126_022-001.jpg (64.31 KiB) Viewed 1418 times
The rear over riders had also suffered the odd minor push - again at heading for £100 each from the Jag parts market the effort taken to straighten them up is worth it
- WP_20140126_023-001.jpg (60.67 KiB) Viewed 1418 times
I will now try to find time to sort the rest of the bits on the car whilst this lot is away being sorted
