Freddie feddling. Finished wiring up the electric fuel pump. Definitely an improvement over the failing mechanical pump, runs so much better, no more stumbling or hesitation. Cleaned up the battery cables at the connections to the battery terminals were loose.
Then removed the brush guard as a) it didn't fit properly, b) was attached to the front suspension mounts = not good. Finally, bolted on the headlights and surrounds and replaced missing bolts to the air dam (under the number plate) as it was hanging down and bugging me.
https://www.youtube.com/watch?v=p389ZIQwxec
My name is Tim and i have an addiction.
Users browsing this forum: No registered users and 37 guests
