Page 34 of 37
Re: Early Javelin Restoration
Posted: Sat Feb 14, 2015 9:59 pm
by Grumpy Northener
Bit more progress today - N/S/R door had been hacked on the inner frame so that the door closed over the check strap bracket that had been reattched with brass at some stage in the cars life
- WP_20150214_005.jpg (59.79 KiB) Viewed 3732 times
With metal cut to shape but such a small piece to try to position whilst its tacked so rather than cut all the way through - I left it part attached to the larger piece so that I could hold it place while it was tacked
- WP_20150214_006.jpg (57.12 KiB) Viewed 3732 times
then just folded it back and forward a couple of times to part - the desired result duly achieved once cleaned up
- WP_20150214_007.jpg (60.23 KiB) Viewed 3732 times
Posted: Sat Feb 14, 2015 10:07 pm
by Grumpy Northener
All of the N/S/R door fitted well with exception of the top frame which was out of line with the front door
- WP_20150214_008.jpg (52.75 KiB) Viewed 3729 times
The fix here was to build up the frame with weld
- WP_20150214_013.jpg (52.69 KiB) Viewed 3729 times
Once cleaned back with the angle grinder and brought into line with a large file on the top edge
- WP_20150214_014.jpg (47.51 KiB) Viewed 3729 times
Posted: Sat Feb 14, 2015 10:20 pm
by Grumpy Northener
I had to previously pack the hinges off on the rear door to obtain the correct gapping against the rear wing - this was achieved with washers on a temporary basis
- WP_20150214_015.jpg (60.67 KiB) Viewed 3728 times
with the door removed and hinges off I made up proper spacer plates utilising the hinges has patterns
- WP_20150214_017.jpg (52.93 KiB) Viewed 3728 times
Posted: Sat Feb 14, 2015 10:32 pm
by Grumpy Northener
- WP_20150214_010.jpg (55.42 KiB) Viewed 3727 times
The spacers left gaps in the door skin abuting the hinge plates so these were made good by welding small plates in
- WP_20150214_018.jpg (50.73 KiB) Viewed 3727 times
- WP_20150214_019.jpg (60 KiB) Viewed 3727 times
So all little odds that took most of the afternoon but the nearside of the car is now very close - it requires a little work in dressing the panels ready for lead loading and a run over with the orbital sander to denib them,
Posted: Sat Feb 21, 2015 11:10 pm
by Grumpy Northener
Before I moved the bodyshell across the workshop to tackle the offside welding on the outer panels I needed to sort the bonnet out
- WP_20150221_001.jpg (35.19 KiB) Viewed 3695 times
The rebates allow for the fastenings for the chrome trim that run down the side of the panel
- WP_20150221_002.jpg (40.55 KiB) Viewed 3695 times
Problem is that these weaken the bonnet and split - whats needed is some form of reinforcement
- WP_20150221_003.jpg (66.77 KiB) Viewed 3695 times
I formed some channel from sheet metal and then formed a radius to match the bonnet profile with the shrinker before letting in the rebates
Posted: Sat Feb 21, 2015 11:19 pm
by Grumpy Northener
- WP_20150221_004.jpg (52.78 KiB) Viewed 3695 times
Clamped up to the underside of the panel I then spot welded the reinforcement in place
- WP_20150221_006.jpg (40.14 KiB) Viewed 3695 times
The holes were redrilled for trim fixing and the splits welded up prior to being cleaned up
- WP_20150221_007.jpg (52.77 KiB) Viewed 3695 times
Posted: Sat Feb 21, 2015 11:26 pm
by Grumpy Northener
Posted: Sat Feb 21, 2015 11:36 pm
by Grumpy Northener
Posted: Sat Feb 21, 2015 11:52 pm
by Grumpy Northener
Main problem with the doors more than anything is that have all had a battering - if new door skins had have been available I would have reskinned all of the doors - they are all going to require quite a lot of work in getting them to the correct profile
- WP_20150221_017.jpg (53.62 KiB) Viewed 3695 times
Meanwhile a couple of areas on the inner panels were made good that had shown through since the shell was dipped some were minor pinholes
- WP_20150221_013.jpg (45.17 KiB) Viewed 3695 times
Others being splits
- WP_20150221_014.jpg (62.1 KiB) Viewed 3695 times
Next on the list is the rear door which requires some minor repairs on the skin but also requires a complete new bottom to the frame.
Posted: Sun Feb 22, 2015 7:16 pm
by vulgalour
Will almost be a shame to put paint on this, it looks fantastic in bare metal with all the work you've put in on it.
