As mentioned previously I plan to use this car as regularly as possible and do some track days / sprints, as such I want to try and tighten the front structure in terms of both handling and longevity, which will basically mean trying to add some discrete strengthening items but overall trying to be sympathetic to the overall appearance of the car
So this is the structure I am using, (the pictures are slightly out of sequence compared to the previous post)
A lateral tube connecting the inner chassis leg to the inner sill (which is hidden in between the toeboard and the footwell and then triangulation from this up to the front crossmember
Where the 'toe board' lateral tube meets the diagonal tube which goes up to the front suspension crossmember
The complete internal triangulation ready to be hidden by the std sheet metal triangulation
I have also closed the sides of the std sheet metal, it helps stiffen the panel which can (in enthusiastic use) crack at the radiused edges, also prevents years of crud collecting inside and rotting from the inside out, just as the original one did. My only reservation is any effect on general cooling to the engine bay - but I guess they will be easy enough to remove if required.
My past experience with reconditioned lever arm dampers wasn't great and its sounds as though not much as changed as to there being unreliable, telescopics are the alternative which necessitates some kind of upper mount either as part of the car or as part of the upper wishbone as are sold commercially, I wanted to mount the damper top in double shear so opted for a body mount.
It attaches to the tubular structure as opposed to just the skin of the sheet metal and should be man enough to take the dampers forces.
And trimming the sheet metal around the mount.
Because I have had to essentially disassemble a complete Heritage inner wheel arch assy I have had to drill out plenty of spot welds, the curved spreader plate didn't fair too well so I had to make another:
Completed, compared to the one I butchered:
Plug welded in place:
Essentially finished from the engine bay view
And from the wheel arch view:
Cheers
